I tried to disable multi line selection, but the related properties doesn't have an effect (see attached screenshot).
Here is the code which I used.
<igDP:XamDataGrid.FieldLayoutSettings>
<igDP:FieldLayoutSettings SelectionTypeRecord="Single" MaxSelectedRecords="1" />
Related to the documentation these are the the related properties.
Why it doesn't work?
By the way:
In the forum post editor I miss a button for Code-Tags.
Also an image upload functionality would be nice.
I see that the attached Image isn't visible (although I added the URL by the image wizard). Additionally I miss an edit button for improving my post.So I write a second post.
Here is the image URL:http://imgbox.com/G5zWPj31
Hello Bryan,
Thank you for your post.
I have been looking into the code snippet and image that you have provided. I created a sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using or send me an isolated sample application where I can reproduce the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
