125
Filter one WebHierarchicalDataGrid based on selected value of another WebHierarchicalDataGrid
I have two tables, Purchase Orders and Purchase Order Lines.   They both appear on the screen at the same time, in separate update panels, one underneath the other.
I would like to capture the value of the field called "POCONumber", in the main POs table, and use it as a filter to filter contents in the PO Lines table.
It would be ideal if I could also write that selected POCONumber value to a session variable.
Solutions can either be in javascript or code-behind; whichever has better performance.
I'm using VB.NET.
<asp:UpdatePanel ID="UpdatePanel1" runat="server">
    <ContentTemplate>
        <ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid3" runat="server" Height="400px" Width="100%" DataSourceID="WebHierarchicalDataSource1" DataKeyFields="ID" EnableAjax="False" EnableAjaxViewState="False" AutoGenerateColumns="False" DefaultColumnWidth="200px">
            <Columns>
                <ig:BoundDataField DataFieldName="ID" Key="ID" Hidden="true">
                    <Header Text="ID">
                    </Header>
                </ig:BoundDataField>
                <ig:BoundDataField DataFieldName="POCONumber" Key="POCONumber">                     <Header Text="POCONumber">                     </Header>                 </ig:BoundDataField>
                <%--ETC.--%>
            </Columns>
            <AjaxIndicator Enabled="True" />
            <GroupingSettings EnableColumnGrouping="True">
            </GroupingSettings>
            <EditorProviders>
                <%--ETC.--%>
            </EditorProviders>
            <Behaviors>
                <ig:Activation ActiveCellCssClass="ActiveCellClass" ActiveRowCssClass="ActiveRowClass">
                </ig:Activation>
                <ig:EditingCore BatchUpdating="True" EnableInheritance="True">
                    <Behaviors>
                        <ig:RowEditing>
                            <ColumnSettings>
                                <%--ETC.--%>
                            </ColumnSettings>
                        </ig:RowEditing>
                        <ig:RowDeleting Enabled="true" ShowDeleteButton="true">
                        </ig:RowDeleting>
                        <ig:RowAdding Enabled="true" EditModeActions-EnableF2="true" EditModeActions-EnableOnActive="true">
                            <EditModeActions EnableOnActive="True" />
                            <ColumnSettings>
                                <%--ETC.--%>
                            </ColumnSettings>
                        </ig:RowAdding>
                    </Behaviors>
                </ig:EditingCore>
                <ig:Selection CellSelectType="Single" Enabled="true" RowSelectType="Single">
                </ig:Selection>
                <ig:RowSelectors>
                </ig:RowSelectors>
                <ig:Paging PageSize="30" PagerAppearance="Bottom" PagerMode="NumericFirstLast">
                </ig:Paging>
                <ig:Filtering>
                </ig:Filtering>
                <ig:Sorting EnableInheritance="true">
                </ig:Sorting>
            </Behaviors>
        </ig:WebHierarchicalDataGrid>
    </ContentTemplate>
    <Triggers>
        <asp:AsyncPostBackTrigger ControlID="btnPOSave" EventName="Click" />
    </Triggers>
</asp:UpdatePanel>
<br />
<br />
<asp:UpdatePanel runat="server" ID="UpdatePanel3">
    <ContentTemplate>
        <ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid4" runat="server" Height="350px" Width="1200px" DataSourceID="whdgsPOLines" DataKeyFields="ID" AutoGenerateColumns="false" EnableAjax="false" EnableAjaxViewState="false">
            <Columns>
                    <Header Text="ID">
                    </Header>
                <ig:BoundDataField DataFieldName="POCONumber" Key="POCONumber" Width="100px">                     <Header Text="PO#">                     </Header>                 </ig:BoundDataField>
                <%--ETC.--%>
            </Columns>
            <EditorProviders>
            </EditorProviders>
            <Behaviors>
                <ig:EditingCore EnableChildlessRowsPopulation="True" EnableInheritance="True" BatchUpdating="true">
                    <Behaviors>
                        <ig:RowEditing>
                            <%--ETC.--%>
                        </ig:RowEditing>
                        <ig:RowDeleting>
                        </ig:RowDeleting>
                        <ig:RowAdding Enabled="true">
                            <%--ETC.--%>
                        </ig:RowAdding>
                    </Behaviors>
                </ig:EditingCore>
                <ig:Filtering>                 </ig:Filtering>
                <ig:Sorting>
                </ig:Sorting>
            </Behaviors>
    </ContentTemplate>
    <Triggers>
        <asp:AsyncPostBackTrigger ControlID="btnSetPONumber" EventName="Click" />
    </Triggers>
</asp:UpdatePanel>
Parents
  • 20255
    Thank you for contacting us.
    My suggestion is to perform client-side filtering. Use Selection behavior in order to get the POCONumber value, and after that apply your custom filter in the second Grid.
    Code snippet:
    //This will return you POCONumber Value
    var selection = ig_controls.WebHierarchicalDataGrid1.get_gridView().get_behaviors().get_selection();
    var POCONumberCell = selection.get_selectedRows().getItem(0).get_cellByColumnKey("OrderID");
    var POCONumber = POCONumberCell.get_value();
    //Get Filtering behavior
    var grid = ig_controls.WebHierarchicalDataGrid1;
    var filtering = grid.get_gridVIew().get_behaviors().get_filtering();
    //Create new filter with some Rule passing the POCONumber value
    var newFilter = filtering.create_columnFilter("POCONumberFilter");
    newFilter.get_condition().set_value(POCONumber);
    //$IG.NumericFilterRules.GreaterThan => 3
    newFilter.get_condition().set_rule($IG.NumericFilterRules.GreaterThan);
    //Apply the new filter
    filtering.add_columnFilter(newFilter);
    filtering.applyFilters();
    More information:
    We provide FilterRules enumerations like NumericFilterRules, BooleanFilterRules, TextFilterRules.
    $IG.NumericFilterRules.All => 0
    $IG.NumericFilterRules.Equals => 1
    $IG.NumericFilterRules.DoesNotEqual => 2
    $IG.NumericFilterRules.GreaterThanOrEqualTo => 4
    $IG.NumericFilterRules.LessThan => 5
    $IG.NumericFilterRules.LessThanOrEqualTo => 6
    $IG.NumericFilterRules.IsNotNull => 8
    $IG.NumericFilterRules.IsNull => 7
    If you want to apply Boolean or Text filter then you should use:
    $IG.BooleanFilterRules
    $IG.TextFilterRules
Reply Children
