Hi all!
I try to load .xlsx file with Workbook.Load(filePath) method and fall into exception:
04.03.2015 08.54.33 file.xlsx Ошибка: Infragistics.Documents.Excel.FormulaParseException: The error type specified is not valid. It must be one of the following values: "#NULL!", "#DIV/0!", "#VALUE!", "#REF!", "#NAME?", "#NUM!", or "#N/A".
Portion with error: #ССЫЛКА!
#ССЫЛКА! is the same as #REF! in Excel Russian localization the file was created in.
Is there a way to load workbooks like this?
Thank you!
Hello Elias,
In order to reproduce this behavior I will need a sample file you are trying to load. Can you please send me a copy of the file you are trying to load or file with similar content in order to test it in our side.
Waiting for your feedback.
Hi, thank you for attention to my problem.
You can get the example of workbook here: https://www.dropbox.com/s/c3f8wem6rklwulb/russian_localized.xlsx?dl=0
Thank you for your feedback.
I succeed to reproduce this behavior with the file you have sent me. I am currently investigating this with our Development Team. As soon I got more concrete information about it, I will get back to you.
Thank you for your patience and understanding.
