Hi Team,,
Need help..
I have a web data grid with one of column as boolean hence it is coming as a bound checkbox field.
The issue I am facing is that I am not able to edit the value of any checkbox field of the column if the checkbox is already marked checked.
Here is the HTML of the grid
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px" AutoGenerateColumns="False" DataSourceID="SqlDataSource1"> <Columns> <ig:BoundDataField DataFieldName="ID" Key="ID"> <Header Text="ID"> </Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Name" Key="Name"> <Header Text="Name"> </Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Age" Key="Age"> <Header Text="Age"> </Header> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Score" Key="Score"> <Header Text="Score"> </Header> </ig:BoundDataField> <ig:BoundCheckBoxField DataFieldName="IsActive" Key="IsActive"> <Header Text="IsActive"> </Header> </ig:BoundCheckBoxField> </Columns> <Behaviors> <ig:Activation> </ig:Activation> <ig:EditingCore> <Behaviors> <ig:CellEditing> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="IsActive" ReadOnly="false" EditorID="Editor1"/> <ig:EditingColumnSetting ColumnKey="Age" /> </ColumnSettings> </ig:CellEditing> </Behaviors> </ig:EditingCore> </Behaviors> </ig:WebDataGrid>
Please suggest how I can implement this feature..
Varun
Hello Sharma,
You do not need any editor to check/uncheck the column, so please see if you will be able to do this if you remove this attribute EditorID="Editor1" from the EditingColumnSettings.
I am looking forward to hearing from you.
I think it was build release issue.. I had 2014.1.1015 and after installing the latest Service Release , it got solved..
