I have an igGrid set up as the following:
window.onload = function(){ var numbers = ["0", "1", "2", "3", "4", "5", "6"];// var dataURL = "The url of a REST service that returns data in the same form as 'data' below";var data = [ { "Description": "Poly over pack drum with wheels contents lavel picture and ID number", "Quantity": "1", "TIDnumber": "8281452" }, { "Description": "55 gallon steel ring top drum", "Quantity": "1", "TIDnumber": "8281451" }]; $("#grid").igGrid({ virtualization: false, autoGenerateColumns: false, renderCheckboxes: true, primaryKey: "TIDnumber", columns: [{ // note: if primaryKey is set and data in primary column contains numbers, // then the dataType: "number" is required, otherwise, dataSource may misbehave headerText: "TIDnumber", key: "TIDnumber", width:"10%", dataType: "number" }, { headerText: "Description", key: "Description", width: "70%", dataType: "string" }, { headerText: "Quantity", key: "Quantity", width: "10%", dataType: "string" }, { headerText: "Amount Needed", key: "AmountNeeded", width: "10%", dataType: "string", unbound: true } ], dataSource: data, //JSON Array defined above //where i have been putting dataURL dataRendered: function (evt, ui) { ui.owner.element.find("tr td:nth-child(1)").css("text-align", "center"); ui.owner.element.find("tr td:nth-child(2)").css("text-align", "left"); ui.owner.element.find("tr td:nth-child(3)").css("text-align", "center"); ui.owner.element.find("tr td:nth-child(4)").css("text-align", "center"); }, dataSourceType: "json", width: "100%", tabIndex: 1, features: [ { name: 'Responsive', enableVerticalRendering: false, columnSettings: [ { columnKey: 'TIDnumber', classes: 'ui-hidden-phone' }, { columnKey: 'Description', classes: 'ui-hidden-phone' }, { columnKey: 'Quantity', classes: 'ui-hidden-phone' }, { columnKey: 'AmountNeeded', classes: 'ui-hidden-phone' } ] }, { name: "Selection", mode: "row" }, { name: "Updating", enableAddRow: false, editMode: "rowedittemplate", rowEditDialogWidth: 280, rowEditDialogHeight: '280', rowEditDialogContentHeight: 300, rowEditDialogFieldWidth: 150, rowEditDialogContainment: "window", rowEditDialogRowTemplateID: "rowEditDialogRowTemplate1", enableDeleteRow: false, showReadonlyEditors: false, showDoneCancelButtons: true, enableDataDirtyException: true, columnSettings: [ { columnKey: "TIDnumber", readOnly: true }, { columnKey: "Description", readOnly: true }, { columnKey: "Quantity", readOnly: true }, { columnKey: "AmountNeeded", editorType: "text", editorOptions: { button: "dropdown", listItems: numbers, readOnly: true, dropDownOnReadOnly: true } } ] } ] }); }
for some reason the Grid will bind to the variable data but not dataURL even though the data that is returned from that URL is the same formatting as the data variable.
Any help would be greatly apprectiated,
Thanks!
Jake :)
Hello Jake,
I have created a sample using the code you provided along with a WebAPI service. When I set my igGrid's dataSource to the WebAPI url, I get the data I am expecting. I have attached my sample to this post as a demonstration.
As for why this is not working on your end, it would help to check your network traffic to see if the REST call is returning any errors while trying to bind the data. Please check your network traffic and let me know what data is being returned in the response. Also let me know if you are receiving any javascript errors either through a popup or through your browser's console.
Since we may have some differences in our REST setup, you may need to configure some additional settings. The igGrid does have a restSettings object option for configuring REST settings. You may need to set these to fit your scenario. You can more information on this here:
http://www.igniteui.com/help/iggrid-rest-updating
http://help.infragistics.com/jQuery/2014.2/ui.iggrid#options:restSettings
If you need further assistance with this, please let me know.
Thank you for the response Michael. The network traffic has no errors and that is actually where i got that data from that was in my original post (by copy and pasting it from the response from my service). Also I am using a WCF REST service. I'm not quite sure how that would effect the grid. Also I am a little confused about the REST settings . Would I still need to do something with the datasource such as this "dataSource: dataURL"? Sorry I am very new to the Infragistics tools, especially binding them directly to a URL.
Hi Jake,
If the data being returned from the service is just returned as a JSON array exactly as your "var data" appears, there should not be much else needed in any expected scenario. The JSON array would be returned in the ajax response and applied to the grid. Setting the igGrid's dataSource to the dataURL should work fine as demonstrated in my sample.
If something the data appears the same, then there is something unexpected I may be missing and I would need more information (an error or a sample that reproduces the issue mostly help) to really know what is causing this.
Otherwise, you can compare igGrid settings and the response data from my sample with what you are seeing and note any differences between the two.
