I have issues with buttons in a template field inside the webdatagrid. While clicking on the button it is invoking the javascript method but the page is getting refreshed. How can i avoid the page refresh while click on the button.
Vijay Krishnan
Hello Vijay,
Thank you for posting in the Infragistics community !
I assume that you are using a server side asp button control. To avoid postback you can call return false; in the end of the javascript function that is invoked on button click. You can also use a html <input type="button"> control,which does not trigger a postback on button click.
If these do not help please provide the code for the TemplateDataField and I will suggest accordingly how to resolve your issue.
Hello Hristo,
I have tried whatever you had mentioned here, but still i coud'nt perform the crud functions well.
This is really become a mess. i was about to upgrade the DLL's to ver 14 and changed the controls too.
But really fed up of this webdatagrid, It'll be a great help for me if you can send me a sample webdatagrid with edit and delete button and all this has to be dynamic.
Ultrawebgrid was fine, why did u do this ?, i dont really understand that why you people take these kind of decisions.
Please look into the sample code given below.
protected override void OnPreRender(EventArgs e) { if (!Page.IsClientScriptBlockRegistered("templatedClicked")) { string strCode = @" <script type='text/javascript'> function templatedClicked() { var result = confirm('Are you sure you want to delete this row'); if (result) { //initiate row delete from the client and call the grid's commit var grid = $find('COETableManager_wdgList'); var editing = grid.get_behaviors().get_editingCore();
grid.get_rows().remove(grid.get_rows().get_row(2));
editing.commit();
} else {
//call do postback to load the new selected data in the second grid? __doPostBack(); } return false; } </script>"; Page.RegisterClientScriptBlock("templatedClicked", strCode); }
if (!Page.IsClientScriptBlockRegistered("wdgList_Editing_RowAdded")) { string strCode = @" <script type='text/javascript'> function wdgList_Editing_RowAdded(sender, eventArgs) { var behaviors = sender.get_behaviors(); var addRowBehavior = behaviors.get_editingCore().get_behaviors().get_rowAdding(); var addNewRow = addRowBehavior.get_row(); var activation = behaviors.get_activation(); activation.set_activeCell(addNewRow.get_cell(0)); addRowBehavior.enterEditMode(addNewRow.get_cell(0)); } </script>"; Page.RegisterClientScriptBlock("wdgList_Editing_RowAdded", strCode); } }
private class CustomItemTemplate : ITemplate { public void InstantiateIn(Control container) { Button edit = new Button(); edit.Text = "Edit "; edit.OnClientClick = "BLOCKED SCRIPTreturn GridDepartments_Selection_RowSelectionChanged();";
Button delete = new Button(); delete.Text = "Delete"; delete.OnClientClick = "BLOCKED SCRIPTreturn templatedClicked();";
//HtmlButton edit = new HtmlButton(); //edit.InnerText = "Edit "; //edit.Attributes.Add("OnClientClick", "BLOCKED SCRIPTreturn GridDepartments_Selection_RowSelectionChanged();");
//HtmlButton delete = new HtmlButton(); //delete.InnerText = "Delete"; //delete.Attributes.Add("OnClientClick", "BLOCKED SCRIPTreturn templatedClicked();");
container.Controls.Add(edit); container.Controls.Add(delete); } }
private void BindWebgrid() { COETableEditorBOList boList = COETableEditorBOList.NewList(); boList.TableName = CurrentTable; //init the dal in TableName property define labTableDescription.Text = COETableEditorUtilities.getTableDescription(CurrentTable); ReturnDataTable = COETableEditorBOList.getTableEditorDataTable(CurrentTable); wdgList.Columns.Clear(); DataTable dtGridSource = new DataTable(); int intFlag; int columnIndex = 0; List<Column> lstColumn = COETableEditorUtilities.getColumnList(CurrentTable);
if (wdgList.Columns.Count == 0) { foreach (DataColumn dc in ReturnDataTable.Columns) { DataColumn dcGridSource = new DataColumn(dc.ColumnName, dc.DataType); //dtGridSource.Columns.Add(dcGridSource); BoundDataField bdField = new BoundDataField(true); bdField.DataFieldName = dc.ColumnName; bdField.Key = dc.ColumnName; bdField.Header.Text = dc.ColumnName; bdField.Width = Unit.Pixel(130); wdgList.Columns.Add(bdField);
if (COETableEditorUtilities.getLookupLocation(CurrentTable, lstColumn[columnIndex].FieldName).Length != 0) { if (COETableEditorUtilities.getIsStructureLookupField(CurrentTable, lstColumn[columnIndex].FieldName)) { _includeStructure = true; bdField.Key = "CDXValue_" + columnIndex.ToString(); bdField.Hidden = true; TemplateDataField tcChemDraw = new TemplateDataField(); tcChemDraw.Header.Text = dc.ColumnName; ; tcChemDraw.Key = "ChemDraw_" + columnIndex.ToString(); tcChemDraw.ItemTemplate = new IndexTypeChemDraw(); wdgList.Columns.Add(tcChemDraw); } } else { //Updated on 2008/11/24 to fix the lookup field bug if (COETableEditorUtilities.getIsStructure(CurrentTable, lstColumn[columnIndex].FieldName)) { _includeStructure = true; bdField.Key = "CDXValue_" + columnIndex.ToString(); bdField.Hidden = true; TemplateDataField tcChemDraw = new TemplateDataField(); tcChemDraw.Header.Text = dc.ColumnName; tcChemDraw.Key = "ChemDraw_" + columnIndex.ToString(); tcChemDraw.ItemTemplate = new IndexTypeChemDraw(); wdgList.Columns.Add(tcChemDraw); } }
columnIndex = columnIndex + 1; }
TemplateDataField field1 = new TemplateDataField(); field1.Key = "TemplateColumn1"; field1.Header.Text = "Edit";
this.wdgList.Columns.Add(field1);
TemplateDataField templateColumn1 = (TemplateDataField)this.wdgList.Columns["TemplateColumn1"]; templateColumn1.ItemTemplate = new CustomItemTemplate(); } else { if (wdgList.Columns.Count != 0) { wdgList.Columns.Clear(); } foreach (DataColumn dc in ReturnDataTable.Columns) { DataColumn dcGridSource = new DataColumn(dc.ColumnName, dc.DataType); dtGridSource.Columns.Add(dcGridSource); BoundDataField bdField = new BoundDataField(true); bdField.DataFieldName = dc.ColumnName; bdField.Key = dc.ColumnName; bdField.Header.Text = dc.ColumnName; bdField.Width = Unit.Pixel(130); wdgList.Columns.Add(bdField); }
TemplateDataField templateColumn1 = (TemplateDataField)this.wdgList.Columns["TemplateColumn1"]; templateColumn1.ItemTemplate = new CustomItemTemplate(); } if (dtGridSource.Rows.Count == 0) { if (dtGridSource.Columns.Count == 0) { foreach (DataColumn dc in ReturnDataTable.Columns) { DataColumn dcGridSource = new DataColumn(dc.ColumnName, dc.DataType); dtGridSource.Columns.Add(dcGridSource); } } //for (int intRowCount = 0; intRowCount < DtGrid.Rows.Count; intRowCount++) //{ //dtGridSource.Rows.Add(DtGrid.Rows[intRowCount].ItemArray); //}
dtGridSource.PrimaryKey = new DataColumn[] { dtGridSource.Columns[0] }; wdgList.DataKeyFields = dtGridSource.Columns[0].ColumnName;
//Create Filtering Behaviour this.wdgList.Behaviors.CreateBehavior<Filtering>();
//Create Sorting Behaviour this.wdgList.Behaviors.CreateBehavior<Sorting>();
//Create Row Selectors Behaviour this.wdgList.Behaviors.CreateBehavior<RowSelectors>();
if (wdgList.Behaviors.Filtering.Filtered == true || ((System.Collections.CollectionBase)(wdgList.Behaviors.Sorting.SortedColumns)).Count != 0 || wdgList.Behaviors.RowSelectors.Enabled == true) { wdgList.Behaviors.Clear(); this.wdgList.Behaviors.CreateBehavior<Filtering>(); this.wdgList.Behaviors.CreateBehavior<Sorting>(); }
//Initalize The Client Method For Columns View And Tooltip //wdgList.ClientEvents.Initialize = "initGrid”; //wdgList.ClientEvents.AJAXResponse = "initGrid”; wdgList.Height = Unit.Pixel(500); wdgList.Width = Unit.Pixel(700); wdgList.DefaultColumnWidth = Unit.Pixel(50); //Create Virtual Scrolling Behaviour VirtualScrolling vrtScrolling = this.wdgList.Behaviors.CreateBehavior<VirtualScrolling>(); vrtScrolling.RowCacheFactor = 50;
//Create Row, Column & Cell Selection Behaviour Selection gridSelection = this.wdgList.Behaviors.CreateBehavior<Selection>(); gridSelection.CellClickAction = CellClickAction.Row; gridSelection.CellClickAction = CellClickAction.Cell; gridSelection.RowSelectType = SelectType.Multiple; gridSelection.ColumnSelectType = SelectType.Multiple; gridSelection.CellSelectType = SelectType.Multiple;
//Create Paging Behaviour Paging gridPaging = this.wdgList.Behaviors.CreateBehavior<Paging>(); gridPaging.PagerAppearance = PagerAppearance.Bottom;
gridPaging.PageSize = 15; gridPaging.QuickPages = 2;
//Create Row Selectors Behaviour RowSelectors rowSelectors = this.wdgList.Behaviors.CreateBehavior<RowSelectors>(); rowSelectors.RowNumbering = true;
//Create Activation, Column Moving & Column Resizing Behaviours this.wdgList.Behaviors.CreateBehavior<Activation>(); this.wdgList.Behaviors.CreateBehavior<ColumnMoving>(); this.wdgList.Behaviors.CreateBehavior<ColumnResizing>();
//Create CellEditing Behaviour this.wdgList.Behaviors.CreateBehavior<EditingCore>(); this.wdgList.Behaviors.EditingCore.Behaviors.CreateBehavior<CellEditing>();
//Create RowAdding Behaviour this.wdgList.Behaviors.CreateBehavior<EditingCore>(); this.wdgList.Behaviors.EditingCore.Behaviors.CreateBehavior<RowAdding>();
//Create Deleting Behaviour this.wdgList.Behaviors.CreateBehavior<EditingCore>(); this.wdgList.Behaviors.EditingCore.Behaviors.CreateBehavior<RowDeleting>();
// Create Edit Cell Settings EditingColumnSetting settingEditColumn = new EditingColumnSetting(); settingEditColumn.ColumnKey = dtGridSource.Columns[0].ColumnName; settingEditColumn.ReadOnly = true; settingEditColumn.EditorID = dtGridSource.Columns[0].ColumnName;
// Create Add Row Settings RowAddingColumnSetting settingAddColumn = new RowAddingColumnSetting(); settingAddColumn.ColumnKey = dtGridSource.Columns[0].ColumnName; settingAddColumn.ReadOnly = true; settingAddColumn.EditorID = dtGridSource.Columns[0].ColumnName;
// Edit Cell, Add Row & Delete Row settings this.wdgList.Behaviors.EditingCore.Behaviors.CellEditing.EditModeActions.EnableOnActive = true; this.wdgList.Behaviors.EditingCore.Behaviors.RowAdding.EditModeActions.EnableOnActive = true; this.wdgList.Behaviors.EditingCore.Behaviors.RowDeleting.Enabled = true;
this.wdgList.Behaviors.EditingCore.Behaviors.CellEditing.ColumnSettings.Add(settingEditColumn); this.wdgList.Behaviors.EditingCore.Behaviors.RowAdding.ColumnSettings.Add(settingAddColumn);
wdgList.DataSource = ReturnDataTable; wdgList.DataBind();
