Hello
I have multiple xamgrid on one xaml form. I am facing problem, if I select a row of one xamGird and move to another xamGrid then selected row doesn't not deselect automatically and both grid rows looks selected which is a kind of weird.
Could you help me to find a solution that one row should appear selected of focused grid?
Hello Amit,
Thank you for your post.
I have been investigating your issue and what I can suggest is to handle the LostKeyboardFocus event for each XamGrid. In the event handler you can use e.NewFocus method to determine where is the new focus. If is it outside of the XamGrid, you can loops all records and set the IsSelected propriety’s of active record to false. I created a short sample application based on your scenario to show you how you can achieve your requirement.
Please let me know of you need any further assistance on the matter.
Thanks It helps.
