105
Disable Multi-Column Tree BringIntoView on Select
When the last visible node in a (multi column) UltraTree is selected and there is a scroll bar, the node is automatically brought into view i.e. the tree scrolls 3 nodes down. I'd like to disable this behavior and keep the node down where it is, even if this means that it is not fully visible.
Is there any way to do this?
Parents
  • 12480
    Verified Answer
    Hi Akrostichon,
    This is expected behavior. When a row in the grid is activated, it is automatically scrolled into view.
    May I ask a bit about your use case? Is this something that is happening programmatically? If so, you can select the row without activating it.
    If you mean that the row is scrolled into view as the result of a user action, please let me know and I will explore other options.
Reply Children
No Data
