I have bool property ShowDateOfService. Setting true or false value to ShowDateOfService property based on some condition but XamDataGrid column is not visible/hide.
My Code is here:
public class LinkToDocumentViewModel : ViewModelBase
public ObservableCollection<DocumentRow> DocumentsToLink { get; set; }
public bool ShowDateOfService { get; private set; }
#region Constructor public LinkToDocumentViewModel(ReferralDocumentLinks referral) { ReferralDocumentInformation = referral; Initialize(); }
public void Initialize() {
ShowDateOfService =false;
GetSearchedDocuments();
private void GetSearchedDocuments()
if(basedonDate = 1)
ShowDateOfService =true;
else
LinkUnlinkToDocument.xmal as below
<igDP:XamDataGrid x:Name="DocumentToLinkGrid" DataSource="{Binding DocumentsToLink}" BorderBrush="Gray" BorderThickness="1" Width="Auto" ScrollViewer.HorizontalScrollBarVisibility="Auto" GroupByAreaLocation="None" VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Margin="0,5,0,0" ScrollingMode="Immediate">
<igDP:Field AllowEdit="False" Name="DateOfService" Label="Date of Service" Width="*" Visibility="{Binding DataContext.ShowDateOfService,Converter={StaticResource BooleanToVisibilityConverter},RelativeSource={RelativeSource FindAncestor}}">
<igDP:Field.Settings> <igDP:FieldSettings EditorStyle="{StaticResource DateEntryFormatStyle}"/> </igDP:Field.Settings> </igDP:Field>
</igDP:XamDataGrid>
I used BooleanToVisibilityConverter for Data grid column and Bind ShowDateOfService value.
But DataGrid column is not hide when i set ShowDateOfService =false.
Please suggest how to hide XamDataGrid column.
Hi P R,
If you are using 14.2 or 15.1, please see the following documentation: http://help.infragistics.com/doc/WPF/2015.1/CLR4.0/?page=xamDataGrid_Binding_Field_FieldLayout_to_MVVM.html
The other thing you need to consider is that ShowDateOfService does not implement INotifyPropertyChanged, so when you change it's value it will not update the UI. You need to implement INotifyPropertyChanged on that property if you want the UI to react to it.
I tried for INotifyPropertyChanged on that ShowDateOfService property.
But it is not working.
