Let me start by stating that I do not want a Stacked Column Series, because it is too difficult to determine the fragment series value using the Y axis. I want to overlay series onto the same X Axis and use a translucent color so I can see overlapping series through those on top of it.
Hi Ed,
Thank you for your post. I was looking into your requirement and was wondering whether you had looked into the StackedBarSeries:
http://help.infragistics.com/Help/Doc/WPF/2014.1/CLR4.0/html/xamDataChart_Category_Stacked_Bar_Series.html
I believe that you can find them helpful.
Let me know, if you need any further assistance on this matter.
No this will not work.
The Stacked Bar Series is just like the Stacked Column Series, just on it's side. When I look at the Oil production in the Stacked Bar Series, and align it with the values in the X-Axis, it appears that it should have a value of ~1450TWh. But that is not the case, it's value cannot be determined by looking at how it is aligned with the axis, you have to guess. This is also demonstrated in the Infragistics WPF Sample Browser under xamDataChart/Display/Gallery - Category Series. If you first look at the standard Column Series or Bar Series, you can see the value of the Oil Measurement for China. Now switch to Stacked Column Series or Stacked Bar Series And look at Oil for China, it looks like it is at ~2400TWh!!!
What I expect is the Oil (since it is the smallest value in the category) to be at the very bottom, so I can look at its height, and associate with a value on the measurement axis. Then whomever is the next higher in that category to be displayed and so on.
Thank you for your reply. Could you please attach a descriptive screenshot on the desired appearance that you would like to achieve?
Hello again!
Here is an image of the graph I want to create. I have an image from the WPF Sample browser on the left and what I want on the right.
Do you see how it is easy to reference each value to the Y-Axis?
Please look at this link for the full size image. The image is larger than fits in the window.
http://keystarsystems.com/graphics/OverlayBarGraph.png
if you set Overlap on the x axis that they share to 1 then the columns will overlap entirely.
But will they only overlay on the specific category, or will every category overylay each other?
they will overlay within each category, the categories themselves remain separate.
Hello Ed,
The overlay does in fact happen. However, it is possible that a column series with a larger value is overlaying a previously rendered column series with a smaller value in the same category. When that happens, it looks like some column series just don't have a value for that category when there actually is, but it's just hidden.
Thank you for your reply. This sounds like expected behavior. I believe that Graham can say if this behavior can be changed but it seems that you need 3D visualization of the XamDataChart which is currently not available.
