I'm trying to get the IgExcel (WPF) sample working and am having trouble with Infragistics Ultimate 15.1, and VS2013 Update 4.
There appears to be missing files from the download - (as the initial problem) - and it seems like there is something definitely wrong. I am nearly certain I have run this sample on 14.2 on another machine in the past and have had no problem.
(FYI, The initial missing file is an icon from igExcel/igExcel.ico - but there appears to be a lot more wrong.)
Note I have just tried it on a different machine altogether with the same result. I have also re-downloaded the sample source with no change.
Is anyone else having issues in running the igExcel sample on the latest tools (15.1) ?
Hello-
After a bit more digging, I have found that if I use the template that is provided within Visual Studio itself under C# | Infragistics - the Excel (and Word) projects that are generated are correct and work fine. It appears to be only the projects that are downloadable from the infragistics site (http://www.infragistics.com/sample-applications/wpf-igexcel) that has the issue I described.
Thanks!
Hello behadfield,
Thank you for your feedback.
Please use the Visual Studio’s templates until the issue is resolved.
Sincerely,
Radko Kolev
www.infragistics.com/support
