I am building webdatagrid using dropdownprovider dynamically.
Once loaded the dropdown the values are loadded correctly but when i click on the dropdown its show only empty container. It will not show the values.
other dropdown in the webdatagrid are showing correctly. but one those values more ie 100 items like will not show the values
Please urgent this issue please guide me.
Satya.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hi When you using your test project there is no issues. but when i am integrating the same code into my application then the dropdown list items will not display properly.
I am attached the extracted files from my application. Please something .css files are hiding the dropdown data.
Hello Satya,
I am not able to see your sample, in oreder to attach it please zip it.
See the attached extracted files from application
Please provide ASP Project sample which reproduces the issue or modify the provided one by me.
Thanks.
HI,
Please find the attached project for reproduce the datagrid dropdown display issue.
Please help me out resolve ASAP. its quite urgent i spent lot of time on this.
Please take look at line 173 in DrpdwnProvider1.aspx.vb from your latest attachment you are setting the dropdown container to have height of 0.
Hope this helps.
Hi Denis Georgiev,
Thanks a lot for the solution its works for me but if I remove the height. then there is showing the height which is very long. so how can i control dynamically the height based on the each item values in the dropdown?
You can suggest this as a new product idea for future versions at <http://ideas.infragistics.com>.
Steps to create your idea:
1. Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The benefits of submitting the product idea yourself include:
- Direct communication with our product management team regarding your product idea.- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the product idea system include:- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.- Allow you to shape the future of our products by requesting new controls and products altogether.- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Hello Veera,
I am still following up. Have you been able to submit your product idea?If you have any concerns or questions, please feel free to contact me, I will be glad to help you.Thank you for choosing Infragistics components!
