I'm using a xamDataChart w/ NumericYaxis, that crashes when the Yaxis has very large values, for ex 5e25 (the full range being 0 to 5e25). Below is some debug info that seems to point to an overflow; a double passed to a fcn that accepts decimals. However, as 5e25 fits within both types not sure why it would crash like this. Also the NumericXaxis doesnt seem to have this issue, it can handle DBL_MAX from what I can tell.
Frank
System.OverflowException
Value was either too large or too small for a Decimal.
System.Decimal.FCallMultiply(System.Decimal ByRef, System.Decimal ByRef) System.Decimal.op_Multiply(System.Decimal, System.Decimal) Infragistics.Controls.Charts.AutoRangeCalculator.CalculateRange(Infragistics.Controls.Charts.NumericAxisBase, Double, Double, Boolean, Int32, Double ByRef, Double ByRef) Infragistics.Controls.Charts.LinearScaler.CalculateRange(Infragistics.Controls.Charts.NumericAxisBase, Double, Double, Double ByRef, Double ByRef) Infragistics.Controls.Charts.StraightNumericAxisBase.CalculateRange(Infragistics.Controls.Charts.NumericAxisBase, Double, Double, Boolean, Int32, Double ByRef, Double ByRef) Infragistics.Controls.Charts.NumericAxisBase.UpdateRangeOverride() Infragistics.Controls.Charts.Axis.UpdateRange(Boolean) Infragistics.Controls.Charts.ContentInfo.UndirtyRange() Infragistics.Controls.Charts.ContentInfo.DoRefresh() Infragistics.Controls.Charts.ChartContentManager.DoRefresh()
Thank you for your post.
I have been looking into it. I created a sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
I am just checking if my last reply was helpful for you.
If you require any further assistance please do not hesitate to ask.
