I have a XAMDatagrid where the data source has columns EX: (Id, Name, Description_Parent, Category) and I have hooked up XAMMultiColumnEditor control for the Category column and I have set ItemSource (EX: Category Name, Category Id, Description) for that editor.
When I pull the drop down, I want to filter the data source based on the "Description_parent" value from the parent row.
Ex: If my XAMDatagrid row has "ECE" as the value for the Description property, I want to filter rows in XAMMultiColumnEditor drop down where Description=="ECE"
I was able to achieve this functionality in Windows forms using ColumnFilters feature of WinGrid. Please let me know how can I achieve this in WPF?
Thank you for your post.
I have been looking into it and I am not sure that I understand correctly your requirements. Would you please provide me with more details about them. Do you want to filter the XamMultiColumnComboEditor by the next cell`s value of current row or you have some hierarchy level and want to filter the items in XamMultiColumnComboEditor based on parent record cell value. It seems like I am missing something about your scenario, so could you please send me, an isolated sample project, where this is reproduced, so I can investigate it further for you.
yes, exactly. I want to filter the XamMultiColumnComboEditor by the next cell`s value of current row.
I am using XamMultiColumnComboEditor within XAMDataGrid. I have 2 columns that uses XamMultiColumnComboEditor .
Ex: Col A and Col C - uses XamMultiColumnComboEditor
Col B - Read only column
Based on the value selected in col A and Col B, i want to filter col C's datasource and show a restricted list when user clicks on col C's drop down. How can i achieve this functionality?
Any update?
Thank you for your feedback.
After working on the functionality that you are trying to achieve and doing some research, the ability to filter the XamMultiColumnComboEditor based on others cell`s value, has been determined to be a new product idea. You can suggest new Product Ideas for future versions (or vote for existing ones) at http://ideas.infragistics.com.
Steps to create your idea:
1. Log into the Infragistics Product Ideas site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
• Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
• Include a link to this thread in your idea so product management will be able to look back at this case.
The benefits of submitting the product idea yourself include:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the Product Idea system include:
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thanks for checking. Is there any work around for achieving this functionality (thru Model ICollection View) ? Can you please send me a sample.
We used column filtering functionality in infragistcis winforms Ultradropdown.
I have been looking into it. As I mentioned in my previous post, currently our XamMultiColumnComboEditor does not support this filtering functionality. About your question for any work around, I am not sure how is organize your data and what are your fully requirements, that I can suggest is to try to create cascading XamMultiColumnComboEditor by using SelectedValue and SelectedValuePath properties. You can take a look at the following link from our online application samples: http://www.infragistics.com/samples/wpf/multicolumn-combo/mcc-using-selected-value-property , where you can find similar sample application , also you can find the same sample in our WPF Samples Browser under the tag: XamMultiColumnComboEditor -> Editing&Selection -> Using SelectedValue/SelectedValuePath Properties.
Please let me know if you need any further assistance on the matter.
