Other than the Firefox the ToolTip on graphs is not coming.There comes no text when you hover over on the data points on graphs.
It seems there is no such issue reproducible with the latest version. You could observe the expected tooltips under all browsers using our online samples at: http://www.infragistics.com/samples/aspnet/chart/creating-and-using-custom-tooltips http://www.infragistics.com/samples/aspnet/chart/adding-tooltips-to-a-chart
Could you add some more details? Please let me know that the exact version you are experiencing this issue with is, as well as what are the browsers versions this is reproducible with. A runnable code sample illustrating the issue or at least sharing the code in use could help further investigate this. It is of course possible you are using outdated version not being supported under latest browsers. For details consider the following resource: http://www.infragistics.com/support/supported-environments
Thanks for the quick response. Below are some more details
