Hello.
i used fomatter.
dataSource is [{"phase": 0},{"phase": 1}.....]
var phaseTable = [ { "phase": 0, "name": "kaihatsu" }, { "phase": 1, "name": "unyou" }, ];
this.getPhaseName = function(phase) { var i, category, val; for (i = 0; i < phaseTable.length; i++) { category = phaseTable[i]; if (category.phase== phase) { val = category.name; } } return val; }
{ headerText: "phase", key: "phase", dataType: "number" , formatter: getPhaseName },--------------------
It could be confirmed to be able to show "kaihatsu" and "unyou" to a iggrid.
I'd like to filter it by inputting "kaihatsu" or "unyou".
When inputting "0" or "1", it can be filtered.
please help me.
Hello hide gotoh,
It's not possible to filter column with number datatype using string conditions out of the box. Instead I suggest you to define unbound column similar to the number column, populated with string data in order filtering expressions for this column to be properly updated. For instance:
var phaseTable = [ { "phase": 1, "name": "kaihatsu" }, { "phase": 2, "name": "unyou" }, { "phase": 3, "name": "kaihatsu" }, { "phase": 4, "name": "unyou" } ];
function populateUngoundColumne(data, grid){ return data["name"]; }
columns: [ { headerText: "phase", key: "phase", dataType: "number" , formatter: getPhaseName, hidden: true }, { headerText: "phase", key: "fakePhase", dataType: "string" , unbound: true, formula: populateUngoundColumne }, { headerText: "name", key: "name", dataType: "string" } ]
If you have further questions, please let me know.
Tsanna
