How to spread the wedges in a radial menu uniformly? I mean all the wedges should be of same size.
I tried setting WedgeSpan and other properties.
Prasad
Hi Prasad,
Thank you for posting in our forums.
What you can do in your case is to set the WedgeCount property to the count of the tools in the menu. This way the tools will fill the whole available space and they will have identical size. You can do this the following way:
ultraRadialMenu1.MenuSettings.WedgeCount = ultraRadialMenu1.CenterTool.Tools.Count;
Please let me know if you have any additional questions.
I tried setting this. But didn't work as expected.
Attached the sample project.
