Hi Sir,
I am implementing webdatagrid on my page and while adding new row I am getting 0 value is already present inside the textbox and dropdown field.
Same I have attached image.
Please suggest some solution on this.
Mahesh Pol
9870253976
Hello Mahesh,
We'll be more than happy to bring this issue into our developers' attention, but first we definitely need a reproducible sample with the exact scenario. In order to do that, we would like you to either provide us with more details on how to exactly mimic your scenario or to provide us directly with a project that reproduces the issue.
Once we determine that we have this sample by either making it, or receiving it, we would be more than happy to look into this and see what causes this undesired behavior.
Hello,Have you been able to resolve the issue?If you have any concerns or questions, please feel free to contact me, I will be glad to help you.Thank you for choosing Infragistics components!
Issue :-
I have implemented BoundDataField for the webdatagrid columns and I am doing some business calculation on adding new row in webdatagrid.
so in this scenario I am getting 0 as default value for the adding new value in the webdatagrid textbox as shown in the previous attachment.
My Analysis:-
When I used the UnboundField I didn't get the 0 value in the webdatagrid textbox but my calculated value is not appearing it in the price field of webdatagrid during runtime.
I am attaching the script code.
Please let me know how can I avoid 0 value populating in the webdatagrid.
Note :- In the attached script file we have implemented steradvancedwebdatagrid which we have override the webdatagird class.
It is the same thing as we have some customization thing so that we did override it.
However I was not able to reproduce the behaviour that you're seeing on your side. I have attached the sample project I used to test this. Please test this project on your side; whether or not it works correctly may help indicate the nature of this issue.
If this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance
Thank you for quick response.
I observed that in your code you have implemented Infragistics4.Web.v14.2 so in version 14.2 you might resolved this issue.
But we are using here version 11.1 and issue is exists in this version.
Please provide me some solution on this.
Hi Mahesh,
The classic controls are retired and no longer supported. They are also not included in NetAdvantage versions 11.2 and above. I would suggest you to migrate to the new controls based on our Aikido framework. Here you can find more information on the matter:
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2013.1/CLR4.0/html/Classic_Control_Migration_Guide.html
http://www.infragistics.com/community/blogs/taz_abdeali/archive/2010/03/04/asp-net-product-changes.aspx
