I'm using version 14.1.20141.2392 for webdatagrid and facing some issue about the width and header of webdatagrid.
When I set the width of the webdatagrid to 100%, the header of the webdatagrid will expand out, please see the second pic in the attachment.
If I removed the width="100%", under higher resolution there is no problem. But under lower resolution, the whole datagrid will go outside of the panel. Please see the first pic in the attachment.
Could you please advise how to fix this issue? If have to set the width="100%", how to make header not expand out?
Bill
Thank you for contacting us!
Providing more information will be highly appreciated, for example with which browser this behavior is happening, when exactly (for example after you have upgraded you product with the current service release 2392), do you have some custom styles applied to your page.
Or you can just send to me isolated sample that is showing the issue.
I uploaded example site code.
There are two webdatagrid, the first one represent the example when columns' total width is bigger than updatepanel, if no width="100%" is set, webdatagrid will go outside of the panel. If set the width="100%" it will be fine BUT for the same webdatagrid if under higher resolution screen the columns' total width will be smaller than the updatepanel, then the header will go outside of the webdatagrid as the second webdatagrid shown.
So my dilemma is with same webdatagrid:
If put width="100%", for the user with higher resolution, the header will go outside of the webdatagrid.
If not put width="100%", for the user with lower resolution, the webdatagrid will go outside of the updatepanel.
Could you please advise how to make the user with higher resolution and lower resolution both work? Maybe some setting needs to be set in ig_res?
By the way, I use IE11.
Thanks.
