We are using XamRibbon 15.1 in my application. Out test team uses Visual Studio Inspect tool to select any ui element and view it's data, for UI automation test purpose.
Now we have a problem, when we select a ribbon tab, we couldn't find any information about the selected tab inside Inspect tool. However if we move the mouse over to the FILE (Application Menu - Mouse Over) menu, then we could see all the tabs getting displayed inside Inspect tool.
Please help.
Sample Xaml Code:
<XamRibbonWindow>
<DocumentContentHost>
<DocumentContentHost.Ribbon>
<XamRibbon />
</DocumentContentHost.Ribbon>
<DocumentContentHost.Content>
<ContentControl />
</DocumentContentHost.Content>
<DocumentContentHost.StatusBar>
<StatusBar />
</DocumentContentHost.StatusBar>
</DocumentContentHost>
</XamRibbonWindow>
Hello Sreek,
Thank you for your post!
I am not entirely sure of the tool that you are referring to by the Visual Studio Inspect tool. I am under the impression that you are referring to the tool commonly found at this directory: C:\Program Files (x86)\Windows Kits\8.1\bin\x64\Inspect.exe. Please let me know, is this the tool you are referring to, or are you referring to something else?
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
YES Andrew, that's what I'm referring.
Hi Andrew,
It doesn't work for us. I have attached a sample application. You can reproduce the issue, that we're facing.
When we run this application, we cannot see any of the ribbon elements. we could see only titlebar elements.
Steps to reproduce:
1. Run the application.
2. Run the Inspect tool.
3. Select 'Show Highlight Rectangle' button in Inspect toolbar.
4. Now, Select a ribbontab/mouse hover app menu/ribbontab - nothing is seen inside Inspect tool.
Sreeni
Please find attachment.
Hello Sreeni,
I have been looking into the sample project that you have provided, and I have reproduced the behavior you are referring to. I have reviewed and discussed this with my colleagues, and it appears that this may be an issue with the XamRibbon control. As a result, I have asked our engineering teams to examine this further. To ensure that it receives attention, I have logged this behavior in our internal tracking system with a development ID of 200669.
I have created a private case for you so that you can track the progress of this development issue. The case number is CAS-156423-G8Z4H3. You can access it here: https://www.infragistics.com/my-account/support-activity.
Hello
We have the same issue here. Is there any ETA of a fix?
Kind regards
Hello Christian,
Are you currently using version 15.1.20151.2055 or 14.2.20142.2224 to test your project? If not, you can download the service release which contains a fix for this issue here: https://www.infragistics.com/my-account/keys-and-downloads.
If you are using the above versions, would it be possible for you to please provide me a sample project that reproduces this issue?
