620
LabelPresenter styling issues
I am styling the LabelPresenter for the WPF XamDataGrid (v 2013.2).  I am using the default theme, and have created this style:
    <Style TargetType="igdp:LabelPresenter">
        <Setter Property="Background" Value="DarkBlue" />
        <Setter Property="Foreground" Value="White" />
        <Setter Property="LabelHighlight" Value="Black" />
    </Style>
See screen capture below for the results of this style.  I have ran into 2 roadblocks:
1) The filter, sort indicator, and pinned icons are too dark.  How can I get l lighter versions of these icons to display?  I know that the Onyx theme uses lighter versions of these icons.  Can I control the icon colors w/out changing the theme?
2) I need to change the background color for columns that are sorted, since it now shows white text on top of a light blue background.  How can I change the background color of sorted columns?  Not applying any special style when the column is sorted would be fine as well.
I looked through the LabelPresenter style in \Program Files (x86)\Infragistics\2013.2\WPF\DefaultStyles\DataPresenter, but was not able to fiture out how to fix either of these problems.
Any help would be greatly appreciated.  Tory.
Parents Reply Children
No Data
