9364
Setting column width causing performance issue
I have a Grid that has a large number of columns, one for each day. There could be 100s of columns in this DataTable for those many days.  After the DataTable is bound to the Grid, I am setting the width of each column as you see in the code snapshot.
I find it hard to understand why setting the Width is so expensive. It takes 24.86 compared to setting the Format on the next line which take only 0.003 . I found it hard to  believe at first but repeated runs of C# profiler confirmed this inefficiency.
Is there a way I can avoid setting the column width one at a time. Is there Grid level or row level setting? Or some other suggestion?
Thanks!
I am on version 7.3
Parents Reply Children
No Data
