Hi...
How do i display loading indicator in web page, we are displaying our pages inside web tabs.
we have one image control inside div in web pages, the code as following
<div id="diaprocess1" class="lodingpanin" runat="server" runat="server"> <img src="../../App_Themes/Simple/IMG/29.gif" alt="Loding.." /> </div>
$("#diaprocess1").dialog({ autoOpen: false, modal: true, resizable: false, width: 500, show: { effect: "fade", duration: 1 }, hide: { effect: "fade", duration: 1 } });
I want to display this dialog box before page loading and hide after completion of page load process,
using opening and closing dialog, the code as following
$("#diaprocess1").dialog("open");
$("#diasearchwin").dialog("close");
but this is not working.
How can i achieve this task??
I am stuck.
Help me out..
Hello Manisha,
You can show any image as loading indicator by setting ImageUrl for the AjaxIndicator of the tab.
I have attached small sample demonstrating this.
Let me know if you need further assistance.
Thank you Georgiev for your solution.
This code is working good but i want to this image to be displayed at the beginning when the page starts loading and hide when the page load is completed.
Currently the loading image displays but only for specific time as given in thread.sleep(2000). and also whenever we change between tabs the image displays again.we need image to be shown only once when page is loading not when switching between tabs.
Thanks in Advance.
I am afraid that I don't understand your requirement.
Please provide sample project demonstrating the issue.
Thanks in advance!
