I'm getting a weird display issue with RowEditing on WebHierarchicalDataGrid, Cell Editing and Row adding display correctly, no errors in the console. I'm using Version=15.1.20151.1018 in firefox. Issue persists on my local and on our dev server. Anyone come across this before?
<ig:RowEditing Enabled="true" EditModeActions-MouseClick ="Single"> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="ChangeType" EditorID="ddlChangep" /> </ColumnSettings> </ig:RowEditing>
ok looks like the screen didn't attach, i'll try again
Thank you for using our forum.
I am not able to reproduce you issue. I am looking at:
http://www.infragistics.com/samples/aspnet/hierarchical-data-grid/row-editing
This may be happen if you are using the 15.1 version, but the styles are from old version (13.2 for example).
Can you send me small sample to reproduce your case
Please let me know if I can provide any further assistance.
Where can I find all the CSS for 15.1? C:\Program Files (x86)\Infragistics\2015.1\ASP.NET\Styles seems to be incomplete (the default folder only has 5 files and there are alot of styles missing RubberBlack for instance which is our sites's default style).
Ten
Hi Ten,
You can find the themes at the C:\Users\Public\Documents\Infragistics\2015.1\ASP.NET\StyleLibraries.
Can you try with this styles?
If it is still reproducible can you send me a small sample with this to can investigate the problem.
looks like the updated styles fixed it, the default has a totally new color scheme
In versions 14.2 and latest the default theme was changed. The old default theme still exists but its name is IG2007.
