I have an issue with UltraGridFilterUIProvider.
After following the steps here: http://help.infragistics.com/Help/Doc/WinForms/2011.1/CLR2.0/html/WinGridFilterUIProvider_Enabling_Enhanced_Filtering_on_WinGrid.html
I get a nice filter icon in the column header, but when I press it, it gives me an entry point not found exception.
Searching for this gave me 2 possible solutions who are not working for me.
- Updating the dll's (they're v15.1)
- execute in x86, which makes no difference
How to solve this?
Hi Sebastiaan,
Thank you for posting in our forums.
I have tried to reproduce this issue using Infragistics v15.1 and everything seems to work properly for me – the filter dialog is shown without any exceptions. What additional settings have you set on the grid? Can you provide us with a small project that reproduces this issue? I have attached the project that I have used to test this so you can use it as a starting point.
I am looking forward to hearing from you.
Well after checking the differences, initially there was no difference visible.
After a closer look at the dll's the issue was they were not up to date. 15.1.20151.1000, where it should be 15.1.20151.2132
Hi Sebastien,
Thank you for the reply.
Are you able to reproduce the issue in the sample I sent you using v15.1.20151.2132? I just tested it with this version and everything is still working properly for me. If you are able to reproduce this in my sample using the 2132 service release, then something in your system must be different than mine. If that’s the case let me know your Visual Studio version and operating system. If you aren’t reproducing the issue in the sample I sent you, please modify it so it reproduces it.
Well with updating to .2132 I have no more issues. it now works fine.
Should've clarified that more in my previous comment.
Thanks for the help.
