Could you please provide me with the full set of drawing images XAML for ComparisonOperatorSelector style? For example, I have the following in my XAML:
<Style TargetType="{x:Type igWindows:ComparisonOperatorSelector}"> <Setter Property="OperatorEqualsImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorEqualsImageKey}}" /> <Setter Property="OperatorNotEqualsImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorNotEqualsImageKey}}" /> <Setter Property="OperatorLessThanImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorLessThanImageKey}}" /> <Setter Property="OperatorLessThanOrEqualToImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorLessThanOrEqualToImageKey}}" /> <Setter Property="OperatorGreaterThanImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorGreaterThanImageKey}}" /> <Setter Property="OperatorGreaterThanOrEqualToImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorGreaterThanOrEqualToImageKey}}" /> <Setter Property="OperatorContainsImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorContainsImageKey}}" /> <Setter Property="OperatorDoesNotContainImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorDoesNotContainImageKey}}" /> <Setter Property="OperatorLikeImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorLikeImageKey}}" /> <Setter Property="OperatorNotLikeImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorNotLikeImageKey}}" /> <Setter Property="OperatorMatchImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorMatchImageKey}}" /> <Setter Property="OperatorDoesNotMatchImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorDoesNotMatchImageKey}}" /> <Setter Property="OperatorStartsWithImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorStartsWithImageKey}}" /> <Setter Property="OperatorDoesNotStartWithImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorDoesNotStartWithImageKey}}" /> <Setter Property="OperatorEndsWithImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorEndsWithImageKey}}" /> <Setter Property="OperatorDoesNotEndWithImage" Value="{DynamicResource {x:Static igWindows:ComparisonOperatorSelector.OperatorDoesNotEndWithImageKey}}" /> </Style>
I also have a few XAMLs for imaeges:
<DrawingImage x:Key="{x:Static igWindows:ComparisonOperatorSelector.OperatorEqualsImageKey}" igWindows:Utilities.SnapElementToDevicePixels="True" PresentationOptions:Freeze="true"> <DrawingImage.Drawing> <GeometryDrawing Brush="{StaticResource FilterOperatorForegroundBrush}"> <GeometryDrawing.Geometry> <PathGeometry Figures="M 0,2 C0,3 0,6 0,6 0,6 10,6 10,6 10,6 10,4 10,4 10,4 0,4 0,4 zM 0,0 C0,0 0,2 0,2 0,2 10,2 10,2 10,2 10,0 10,0 10,0 0,0 0,0 z" /> </GeometryDrawing.Geometry> </GeometryDrawing> </DrawingImage.Drawing> </DrawingImage>
<DrawingImage x:Key="{x:Static igWindows:ComparisonOperatorSelector.OperatorNotEqualsImageKey}" igWindows:Utilities.SnapElementToDevicePixels="True" PresentationOptions:Freeze="true"> <DrawingImage.Drawing> <GeometryDrawing Brush="{StaticResource FilterOperatorForegroundBrush}"> <GeometryDrawing.Geometry> <GeometryGroup FillRule="NonZero"> <PathGeometry Figures="M 0,2 C0,3 0,6 0,6 0,6 10,6 10,6 10,6 10,4 10,4 10,4 0,4 0,4 zM 0,0 C0,0 0,2 0,2 0,2 10,2 10,2 10,2 10,0 10,0 10,0 0,0 0,0 z"> <PathGeometry.Transform> <TranslateTransform Y="2" /> </PathGeometry.Transform> </PathGeometry> <PathGeometry Figures="M 0,10 C0,10 2,10 2,10 2,10 8,0 8,0 8,0 6,0 6,0 6,0 0,10 0,10 z"> <PathGeometry.Transform> <ScaleTransform ScaleX="1.25" /> </PathGeometry.Transform> </PathGeometry> </GeometryGroup> </GeometryDrawing.Geometry> </GeometryDrawing> </DrawingImage.Drawing> </DrawingImage>
etc..
Could you please give me the full set? I cannot access it on my machine, so would appreciate if you could provide all the existing ones to me? Thank you so much.
Anton
Hello Anton,
Thank you for your post.
All of the ComparisonOperator selector "images" are DrawingImage elements, and after installing the Infragistics suite of controls, they can commonly be found in the XAML file at this directory: C:\Program Files (x86)\Infragistics\<your_version_here>\WPF\DefaultStyles\Windows\PrimitivesGeneric_Express.xaml.
For your convenience, I have rounded up all of the ones you have listed above into a single text file, which I have attached to this post.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Hi Andrew,
Sorry, could you also send me over the following operators, because I do not have access to them otherwise:
Top
Bottom
TopPercentile
BottomPercentile
In
NotIn
Thank you so much,
I apologize for that, I should've just included them in the original response. I have attached the updated list of operator DrawingImages.
