We face following problems how to fix that like showing in sample snapshot?
Hi Elinder.
Please find anwers to your questions below:
1.How to place legend inside the chart, currently it is in the left side above the chart?
You can use css to place the element wherever you like, for example:
style="left: 90px; top: 60px; position: absolute;"/>
2.How to left align yaxis label values, currently all values are right aligned?
There is the labelHorizontalAlignment property for axes to achieve that:
{ name: "PopulationAxis", type: "numericY", labelHorizontalAlignment: "left", }
3.Two decimals tooltip values format with comma's like (5,000.00 and 20,000.00) with datetime format?
I didn't understand your query here, could you please clarify ? Do you want to display a numeric value like 2.000 with a comma as a separator ? What about the datetime format ?
4.How to set HorizontalCrosshairVisibility = false ?
You can use the horizontalLineVisibility property of a series object. It takes values "visible" or "collapsed" and collapsed hides the relevant line:
{ type: "crosshairLayer", name: "crosshairLayer", targetSeries: "1995Population", horizontalLineVisibility: "collapsed" }
5.Small sample application is really very helpful for us.
You can find a sample demonstrating how to use the above mentioned properties. I hope it helps.
Hi Hristo,
Thank you so much for quick response, Our mostly problems are solved only few minor issues,
Try with setting a z-index: 10000 css property to the tooltip container element. You can do this in the tooltipShown event. Please let me know if this worked or if would need to search for alternative solution.
I tried this but its not working, can you fix it? We have more issues like
Discussing on multiple issues in the same thread is against Infragistics policies, which is all about keeping a different thread/case for each issue that customers face. This helps tracking and searching and enables us to provide better support. I suggest that you go ahead and open a new case for any issues you are currently facing.
Thanks, I was removed the newly created issues and create a separate thread, please look into my relevant issues of the current thread.
Thank you for following our policy, this is highly appreciated. I am currently looking into current issues and will update the case with my findings and suggestions.
We need to solve these issues on urgent basis, can you look into it and update me?
Any update ?
Please accept my apologies for late response on this. I am currently working onto it and will update this thread shortly.
Please find solutions to your questions below:
1. When we move mouse on chart, values are not rounded on spot its take time to round. How to fix the decimals of all stock prices (open/high/low/close) in pop up to be two digits on spot with out delay ?
Currently I have been using tooltipShown event, because it is needed for the Date label to be formatted. However it causes this time to display the raw values and the rounded ones. To fix this I separated the logic for the labels and execute it in tooltipShowing for labels and tooltipShown for the Date and Volume label.
This is the fix to display with two digist after separator:
newRoundedValue = (Math.round(ui.item[labels[i].innerText.slice(0, -1)] * 100) / 100).toFixed(2); ui.item[labels[i].innerText.slice(0, -1)] = newRoundedValue;
2. Currently vertical crosshairLayer has a delay following the mouse location. How to make them faster?
I am currently investigating what may be the cause of this issue. Does it behave the same way from the beginning, or do you recall started delaying after introducing a feature or functionality to the sample ?
Thanks for updating
