I have an ultragrid with a multiple bands as datasource, and i don't know how to make it to look like in attached image.
The orange area is the data from band[0].
The red area is the data from Band[1].
First, is it possible to make two bands to look like so? (i mean somehow merged, the default appearance is like a tree)
I'm also thinking to another solution - a grid for orange areas, and another grid in a cell of the previous grid, in order to create the red area.
As a note, the red area should behave and look like a grid.
Please, give me any advice how to implement this.
Hello Codrut,
Yes you can achieve such design with UltraGrid. What you need is to create a custom row layout for your Band[0]. More about RowLayout you may find by following the next link http://help.infragistics.com/Help/Doc/WinForms/2012.1/CLR2.0/html/WinGrid_Work_with_Row_Layouts.html.
I have created for you a small sample solution implementing this logic. Please check my sample and let me know if this is what you are looking for or if I am missing something.
Thank you for using Infragistics Controls.
Hello Milko,
Thanks for your quick reply.
Related to my initial question, i work a bit with row layout, and i got that hierarchical structure (tree view with "+" for expanding), but my question is if i could create an UI like in attached image?
As you can see, there is a orange border, and the two bands are "merged", no "+" for expanding/collapse the second band.
Is that possible?
Thank you for your feedback.
Regarding the + signs (expansion indicators) you can hide them by setting the ExpansionIndicator property of the layout override to Never. More about ExpansionIndicator you may find by following the next link http://help.infragistics.com/Help/Doc/WinForms/2015.1/CLR4.0/html/Infragistics4.Win.UltraWinGrid.v15.1~Infragistics.Win.UltraWinGrid.ShowExpansionIndicator.html.
Regarding orange rectangle around each band and row connectors you need to implement IUIElementDrawFilter interface in order to achieve this. You can check my revised sample where I have implement this approach. More about the draw filter you may find by following the next link http://help.infragistics.com/Help/Doc/WinForms/2015.1/CLR4.0/html/Infragistics4.Win.v15.1~Infragistics.Win.IUIElementDrawFilter.html.
Please let me know if you need any additional information.
