I have a problem. I was able to see when I dragged a Appointment over onto the XamDateNavigator and it did show a DragOver effect, where the user would see that the operation is possible. It used to work, but now it does not. I made some changes to the layout of the AppointmentPresenter, but I can't go back with my code far enough to see what it messed up.
I hope you have an idea, what caused this to happen.
Thank you
Hi tegos,
What kind of changes did you make to the layout? Are we talking about changing up the template for the presenter? Even if I provide a very barebones template for the AppointmentPresenter (just a Border and TextlBlock) I am still able to drag the appointment over the date navigator so I don't think that would be the cause. What version of the Infragistics WPF product are you using? If I could get a specific version # for the DLLs that you are using I could test against those.
Hi Rob,
thanks for the quick answer. I am using the 15.1.20151.2055 DLL's. It worked before, thats why I'm curious what could have caused it.
I changed a few things, here is a pastebin: http://pastebin.com/B92w1JPP
Can't you check the source code, what would be necessary, that the DragOver icon is not showing?
