Can you run Infragistics 8.3 (grids, nav. links, tabs, etc. on ) code on Infragistics 15.x? If so, how can it be done?
Hello Sean,
Can you please tell me what technology are you using in your project? Is this Windows Forms application, or ASP.NET or something else?
You can also check Infragistics Supported Environments page to check if your environment is supported. Please follow the next link to navigate to Infragistics Supported Environments http://www.infragistics.com/support/supported-environments.
Looking forward to your reply.
Thank you for using Infragistics Controls.
Sincerely,
We're using Visual Studio 2010 with a 3.5 / 4.0 .NET Framework. We are going to migrate to V.S. 2012 / 4.0
Currently using IE 8 but migrating over to IE 11
Sean,
Many of the controls that you were using in 2008 Volume 3 were likely retired in 2011. There are details on what was retired in the NetAdvantage for ASP.NET Product Changes in 2011 Volume 2 blog post:
http://www.infragistics.com/community/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx
There is a classic control migration guide that helps with knowing what controls in the current toolset would replace the older controls:
http://help.infragistics.com/doc/ASPNET?page=Classic_Control_Migration_Guide.html
You may also want to consider using our jQuery controls to replace the retired controls if they meet your needs:
http://www.infragistics.com/products/jquery
