I am following this sample: http://www.infragistics.com/samples/wpf/grid/summary-row-in-groupby-headers
I have multiple columns that need the same group-by template applied. The sample shows how to do it for one column. Is it possible to do it for multiple columns without simply copying/pasting the template for each column?
Hello Igor,
You can define the template as a resource and set its key property so you can apply it as static resource for the GroupByItemTemplate to as many columns as you want without duplicating the code.If you need additional assistance, do not hesitate to update the forum thread.
Thanks. This turned out to be more of a WPF-in-general question. I'm fairly new to WPF and didn't realize how easy this was.
