Hi I am using ultragrid for my application but I am not able to perform multi select in the grid. I have set the selectrowtype property to Extended but it is not working.
Is there any other possibility that multi select will work properly?
In order to select more than one row, you have to hold down the Ctrl or Shift key - just like in Windows Explorer. If you are doing that and it's still not working, then there must be some other factor at work.
If you are setting SelectTypeRow, then perhaps the property is being reset or changed after you set it. Are you loading a layout into the grid which might be blowing away the property setting?
Are you setting the property on the DisplayLayout.Override or on the band.Override? If you set it on both, then the band will take precedence over the DisplayLayout.
I tried to set it in both Band and Display layout,but yet it is not working. When I did debug in InitialLayout the property is shown as extended but yet it is not working.
