We are using Infragistics NetAdvantage® for ASP.NET 2013.1 - Version 13.1.20131.1012.Please refer to the attachments. We are seeing some black lines on the webdatagrid border in IE8 and IE9.
We would like to have the same look and feel - as that of IE7, for IE8 and IE9 document modes.
Could you please suggest what styling needs to be changed.
Attachment 2
Attachment 3
Hello Jeevitha,
Thank you for contacting us.
This kind of issues appear when Compatibility view mode is used. Could you please try without it and let me know if the borders still appear.
Also you can have a look at our WebDataGrid CSS styling guide, this blog will help you to better understand how to customize your grid styles in a way that will perform without any styling issues in any browser.
Thanks for the response.
Please have a look at the screen shot.
Even when i use browser mode as IE9 instead of IE9 compatibility view, i see differences in the way grid comes up in IE7 document mode with IE8/IE9 modes.
Please suggest asap.
I see it, yes. I can suggest you to update your product (13.1) to the latest SR available because every new release contains a lot of issue fixes and incorrect behaviors, styles etc.
When you update your product and test the sample, could you please let me know about the results.
That was real quick response! Thanks.
Could you please let me know the SR detail which has these fixes.
As well, to support IE11 browser, per this link - http://www.infragistics.com/community/forums/t/91832.aspx, we are looking to update to Version=13.2.20132.2187.
Currently we are running in IE7. We look forward to have the application work in IE8, IE9, IE11, Chrome. What is your take on this? Which version is recommended for these browsers?
I am not entirely sure that any of the fixes will be suitable for you, although it "worth the shot" because each of our SR contains different fixes related to stylizations and incorrect functionalities.
The last SR version available for 13.1 is 2331, and for 13.2 is 2294.
In general it is suggested always to use the latest SR for particular version, and also to use one of the last 3 supported versions, for example version 13.1 and 13.2 are no longer supported for bug fixing:
http://www.infragistics.com/support/product-lifecycle
As for the IE7 support, below you can find a table that is showing environments and OS under which our Product is tested and supported.
http://www.infragistics.com/support/supported-environments
