It seems that default layout doesn't work as expected. It's not applied by default even though fields defined in in this layout are present on underlying objects.
Please see following two issues:
Issue #1:
Expected:
Actual:
Issue #2:
Please also see the comments in MainWindow.xaml file next to layout definition.
Attachment content:
Kind regards,
Artur
Hello Artur,
Thank you for the provided code snippet. I was able to reproduce the flickering issue of the filer and have logged this behavior with our developers in our tracking system, with an issue ID of 204395. I have also created a support ticket on your behalf with number CAS-159525-L5K7J1 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Regarding your other issue with the adding new items to the collection - in order to provide you with better and more accurate support, I have created a separate support ticket for you with number of CAS-159639-C9C8K1. Let's continue our discussion in the support ticket.
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account\My Keys and Downloads.
