775
Issues in enter editing mode with XamDataTReeNode
I am trying to enter edit mode after the node is created using a behavior. However it comes out of the edit mode automatically. Please help where I'm doing wrong.
Code for xaml and behavior:
xaml:
<ig:XamDataTree
ItemsSource="{Binding Path=ProjectCollection}"
ActiveDataItem="{Binding ActiveNode, Mode=TwoWay}"
AutomationProperties.AutomationId="aid_ProjectExplorerTree">
<ig:XamDataTree.EditingSettings>
<ig:TreeEditingSettings AllowEditing="True" AllowDeletion="False" IsEnterKeyEditingEnabled="False" IsF2EditingEnabled="True" IsOnNodeActiveEditingEnabled="False" />
</ig:XamDataTree.EditingSettings>
<ig:XamDataTree.SelectionSettings>
<ig:TreeSelectionSettings NodeSelection="Single" />
</ig:XamDataTree.SelectionSettings>
<ig:XamDataTree.InputBindings>
<KeyBinding Key="Delete" Command="{Binding EditManager.DeleteCommand}" />
<KeyBinding Gesture="Ctrl+D" Command="{Binding EditManager.DuplicateCommand}"/>
<KeyBinding Key="F4" Command="{Binding EditManager.PropertiesCommand}"/>
</ig:XamDataTree.InputBindings>
<i:Interaction.Behaviors>
<behaviors:XamDataTreeCommonBehavior />
<workbench:TreeNodeEditBehavior />
</i:Interaction.Behaviors>
<i:Interaction.Triggers>
<i:EventTrigger EventName="MouseDoubleClick">
<i:InvokeCommandAction Command="{Binding EditManager.OpenCommand}">
<i:InvokeCommandAction.CommandParameter>
<MultiBinding Converter="{StaticResource CapabilityParameterConverter}">
<Binding Source="{StaticResource BindingProxy}" Path="Data.Project"/>
<Binding Source="{StaticResource BindingProxy}" Path="Data.ActiveNode"/>
</MultiBinding>
</i:InvokeCommandAction.CommandParameter>
</i:InvokeCommandAction>
</i:EventTrigger>
</i:Interaction.Triggers>
<ig:XamDataTree.GlobalNodeLayouts>
<ig:NodeLayout Key="Project" TargetTypeName="Project" DisplayMemberPath="Name" IsExpandedMemberPath="ViewData.IsVisuallyExpanded">
<ig:NodeLayout.ItemTemplate>
<DataTemplate DataType="{x:Type structures:Project}">
<StackPanel Orientation="Horizontal" ContextMenu="{StaticResource ResourceKey=ProjectExplorerContextMenu}">
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/Project.png" />
<TextBlock Text="{Binding Data.Name}"/>
</StackPanel>
</DataTemplate>
</ig:NodeLayout.ItemTemplate>
</ig:NodeLayout>
<ig:NodeLayout Key="Proposals" TargetTypeName="Proposal" DisplayMemberPath="Name" HeaderText="Proposals" IsExpandedMemberPath="ViewData.IsProposalVisuallyExpanded">
<DataTemplate DataType="structures:Proposal">
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/RestOf.png" />
<TextBlock Text="{Binding Data.Name}" />
</StackPanel>
</DataTemplate>
<ig:NodeLayout.NodeLayouts>
<ig:NodeLayout Key="ProposalProposalParts" HeaderText="Proposal parts" TargetTypeName="ProposalProposalPart"
DisplayMemberPath="ProposalPart.Name" IsExpandedMemberPath="ViewData.IsVisuallyExpanded">
<DataTemplate>
<StackPanel Orientation="Horizontal" ContextMenu="{StaticResource ProjectExplorerContextMenu}">
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/Proposal.png" />
<TextBlock Text="{Binding Data.ProposalPart.Name}"/>
</StackPanel>
</DataTemplate>
<ig:NodeLayout Key="ViewData.ActiveCommercialScenarioCollection" TargetTypeName="CommercialScenario" DisplayMemberPath="Name">
<DataTemplate>
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/Active.png"/>
</StackPanel>
</DataTemplate>
</ig:NodeLayout>
</ig:NodeLayout.NodeLayouts>
</ig:NodeLayout>
<ig:NodeLayout Key="CommercialScenarios" TargetTypeName="CommercialScenario" DisplayMemberPath="Name" HeaderText="Commercial scenarios">
<DataTemplate>
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/CommercialScenario.png"/>
</StackPanel>
</DataTemplate>
</ig:NodeLayout>
</ig:NodeLayout>
<ig:NodeLayout Key="OrderPlans" TargetTypeName="OrderPlan" DisplayMemberPath="Name" HeaderText="Order plans">
<DataTemplate DataType="structures:OrderPlan">
<Image Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/Order.png" />
</StackPanel>
</DataTemplate>
<ig:NodeLayout.EditorTemplate>
<DataTemplate>
<controls:TextEditor IsAlwaysInEditMode="False" Text="{Binding Path=Data.Name, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}"/>
</DataTemplate>
</ig:NodeLayout.EditorTemplate>
</ig:NodeLayout>
<ig:NodeLayout Key="AssociatedRiskAnalyses" TargetTypeName="RiskAnalysis" DisplayMemberPath="Name" HeaderText="Risk analyses">
<DataTemplate DataType="structures:RiskAnalysis">
</StackPanel>
</DataTemplate>
<DataTemplate>
</DataTemplate>
</ig:NodeLayout>
<ig:NodeLayout Key="ViewData.ProductList" TargetTypeName="String" HeaderText="Product list">
</ig:NodeLayout>
<ig:NodeLayout Key="ProposalParts" TargetTypeName="ProposalPart" DisplayMemberPath="Name" HeaderText="Proposal parts">
<DataTemplate DataType="structures:ProposalPart">
</StackPanel>
</DataTemplate>
<DataTemplate>
<StackPanel Orientation="Horizontal">
<TextBox Text="{Binding Data.Name, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" />
</StackPanel>
</DataTemplate>
<ig:NodeLayout Key="CommercialScenarios" TargetTypeName="CommercialScenario" DisplayMemberPath="Name">
<DataTemplate DataType="structures:CommercialScenario">
<Image x:Name="CommercialScenario" Height="16" Width="16" Margin="1 0" Source="/EAB.Premium.Client.Framework;component/Images/CommercialScenario.png"/>
</StackPanel>
</DataTemplate>
</ig:NodeLayout>
</ig:NodeLayout>
</ig:XamDataTree.GlobalNodeLayouts>
</ig:XamDataTree>
Behavior:
public class TreeNodeEditBehavior : Behavior
protected override void OnAttached()
base.OnAttached();
AssociatedObject.InitializeNode += AssociatedObjectOnInitializeNode;
protected override void OnDetaching()
AssociatedObject.InitializeNode -= AssociatedObjectOnInitializeNode;
base.OnDetaching();
private void AssociatedObjectOnInitializeNode(object sender, InitializeNodeEventArgs e)
var tree = sender as XamDataTree;
var node = e.Node.Data as NodeBase;
if (tree != null && node != null && node.IsEditable)
tree.EnterEditMode(e.Node);
Error from stacktrace:
Parents
  • 775
    Xaml Code:
    <ig:XamDataTree
    Attached stacktrace after enter edit mode and immediately exiting edit mode:
    if I cancel exit edit mode using e.cancel = true in behavior i see a check box node. This is very interesting.
    Please help at the earliest.
    Sreeni
Reply Children
No Data
