1) in controller Infragistics_GridTemplateCell ,I have a template column which is button with event onclick='deleteRow(${ProductName})'.When pressed button method deleteRow not raise.Do you have an idea why it is so?I followed exsample : http://www.igniteui.com/grid/column-template 2) in controller Infragistics_CheckBoxComboBox ,I want to create Checkbox-ComboBox , but checkbox not show.Can you help me with this?(Mvc_Ignite.rar not contain packages folder)Thanks in advance............
Hello ticho,
About your first question, since you're passing a column key to the deleteRow click handler, which is of string data type, it should be surrounded with quotes in order to work properly:
onclick='deleteRow( \"${ProductName}\")'
Please note that if you want to delete a row using the igGrid 'deleteRow' API, you should use the primary key column, because this method works only with a primary key: http://help.infragistics.com/jQuery/2015.1/ui.iggridupdating#methods:deleteRow
About your second question, I believe that you're not using the right MVC wrapper for the igCombo. Here in our documentation is explained how to create basic igCombo in MVC for your reference:http://www.igniteui.com/help/igcombo-getting-started
Please let me know if I can provide you with further assistance.
Tsanna
I tried this ( in exsample ) onclick='deleteRow( \"${ProductName}\")' , but it did not
I'm sending you your project back with the respective modifications. If you have any questions, feel free to contact me.
thanks...
Can I help you with anything else?
