I have updated to Infragistics 15.2 and have encountered an error that does not exist in 14.1.
I have updated the ReadOnly sample application to duplicate the issue involved.I have added 2 new columns to the database and to the grid. I have also added a button to force a post back event. I have AutoCrud = false
When the user clicks on the "Discontinued" checkbox, a value is injected into the "DiscontinuedBy" cell from the JavaScript function _CellValueChanged().
When the user clicks on "Save" button the _RowUpdating() event is fired.In version 14.1 the value of the "DiscontinuedBy" cell is correctly read.In version 15.2 the value of the "DiscontinuedBy" cell is always "".If the user manually types a value into the "DiscontinuedBy" cell, version 15.2 will correctly read the value.
Hi Kenneth Hauldren,
I investigated your sample and found few things:
For more clarity I am sending you a modified sample that will demonstrate the working behavior. Please let me know whether it helps you!
Petko,You tested this using 15.1, not 15.2
This works as expected in 15.1, but the value of the cell is empty when using 15.2I have copied the exact same code to 15.1 and 15.2. The results of each are in the snapshot attached.
Please test this using 15.2 and get back to me.
You are right, in that version, the issue persists. However, I tested it with 15.2.20152.2010 and there the problem is resolved (sending screenshot). So, upgrade to some latest version and it should resolve your issue.
Petko,
I'm having the same issue as Mr Hauldren. So, to your point I checked my dll's version and I too have 15.2.20152.1028. In my sln I clicked on Infragistics in the menu toolbar and then clicked "Check for Latest" - it comes back stating I'm up-to-date. So I went and re-downloaded the 15.2 platform installer and I still end up with 15.2.20152.1028. How do I get 15.2.20152.2010?
Thank you,
John Price
Petko,I downloaded the lastest version of Infragistics Ultimate just now, and it is still version 15.2.20152.1028 as evidenced by the screen shot attached.
This defect is causing us serious issues and we need a working version.What has to happen to get .2010?
It seems that the last public build is 15.2.20152.1028. The next official release will be on 11-Dec-2015 (source - http://www.infragistics.com/support/service-releases). You can download new build then or if you in a hurry you can request private build in a case.
It seems that this volume 15.2 "BUG" rears its' head in other ways also! If a grid column initial value is null or empty string, the new value always returns an empty string regardless of the new value inserted. If I modify the stored proc to use a string of " " in place of a null or empty string in the initial dataset bound, the grid will now return the new value in the RowUpdating event.
Is it possible to get an update sooner as I would like to test it to make sure this fixes my issues in production code...
