320
Changing cell back color based on value
I have a WebDataGrid with two columns. What I want to do is, that if the value in a cell of the first columns is lower then the cell in the 2nd column I want to have this cells back color as green, otherwise as red.
In the classic WInGrid that was not a problem but I am really lost here.
Any help is appreciated.
Thanks & Regards,
Oliver
Parents
  • 5513
    Suggested Answer
    Hello Oliver,
    You can accomplish this by using some client-side code.
    First handle the Initialize client-side event fired by the WebDataGrid control.
    <ig:WebDataGrid ID="WebDataGrid1" runat="server">
            <ClientEvents Initialize="initialize" />
    </ig:WebDataGrid>
    The handler will look like this:
    function initialize(sender, eventArgs) {
            //gets all rows
            var rows = sender.get_rows();
            //iterates through the rows
            for (var i = 0; i < rows.get_length(); i++) {
                //gets the current row
                var row = rows.get_row(i);
                //gets the first and the second cell of the current row
                var cell1 = row.get_cell(0);
                var cell2 = row.get_cell(1);
                //compares their values
                if (cell1.get_value() > cell2.get_value())
                    //adds a class with custom properties for the cell
                    cell1.get_element().classList.add('red');
                else
                    cell1.get_element().classList.add('green');
    This example expects two classes to be added to the stylesheet.
    .red
        background-color: Red ! important;
    .green
        background-color: Green ! important;
    Hope this helps. Please let me know if you need further assistance.
    Best regards,
    Stamen Stoychev
Reply Children
No Data
