I would like to use the XamComboEditor, but in your sample browser the list is always docked at the left of te window. How can I have the list under the comboeditor?
Ingmar
Hello Ingmar,
Thank you for your post!
The issue you have described is similar to one that was already reported and is only reproducible on a touch enabled machines. Would you please let me know if you have the touch support enabled on your machine? If that is the case I could create a support ticket for you and link it to the existing item in our system so you are automatically notified when the fixed is released.
If you do not have the touch support enabled, could you please share more details for your environment so I could reproduce the issue since this seems to not reproduce on non-touch laptop running Windows 8.1, 64 bit.
I have a Microsoft Surface with Windows 8.1, 64bit. Please let me know if it is fixed
I have created the following support ticket CAS-167109-W1M8X8 so you are automatically notified when the fix for this issue is released. The fix for WPF will be released with the next Service Release (http://www.infragistics.com/support/service-releases).
The development issue 209145 has been fixed. The fix is available in the latest Service Release 15.2.20152.2038. You can download the Service Release by logging in our web site and then going to Account\My Keys and Downloads page.
