535
CategoryXAxis label positioning
When using xamDataChart with values on Y-axis and categories on X-axis, I get this behavior seen in picture below. So when one or more of the labels span on multiple lines, all others get misaligned. I have to use that kind of angle on these labels.
So how could I get all the labels to be on the same place(on the X-axis) as the corresponding value points?
Label mismatch
Parents
No Data
Reply
  • 28496
    Thank you for reporting this.  It looks like a bug, triggered by the fact that the rotation for all labels is done based on the height of the tallest label.  I have entered a bug report, #213973.  It should be resolved in an upcoming service release.
    I tried coming up with a workaround for some time, but I think the only options are to avoid the multiline title or to avoid rotation.  Note that with TextWrapping=True, horizontally oriented labels will be drawn as multi-line in order to avoid collisions.
Children
