Hi Team,
I'm new to Charts and using Infragistics 13.2. I'm trying to create a Graph with secondary axis from Datatable.
Below are the columns
Date|TAT|Count
and I want to show chart as attached file. Can you please help me with sample how to get below with Ultrawinchart?
Hi Harish,
I’m working on a sample that demonstrates how to achieve this look using UltraWinChart, I will post the sample on this thread by tomorrow, but the below information should get you started with your UltraChart.
To create a secondary axis from a data table you have to create a Series object and assign your DataTable to it. For example you have to do something like this.
DataTable dt = new DataTable();
dt.Columns.Add("2007", typeof(int));
dt.Columns.Add("2008", typeof(int));
dt.Columns.Add("label", typeof(string));
dt.Rows.Add(new object[] { 10, 15, "Month1" });
dt.Rows.Add(new object[] { 20, 25, "Month2" });
NumericSeries series1 = new NumericSeries();
series1.Data.DataSource = dt;
series1.Data.ValueColumn = "2007";
series1.Data.LabelColumn = "label";
chart.CompositeChart.Series.Add(series1);
To achieve this look for your chart you need to create a composite chart with two chart layers in it. One chart layer containing the Bar chart and another chart layer containing a Line chart. You can refer to the below link on how to create a composite chart using the Chart Wizard.
http://help.infragistics.com/Help/Doc/WinForms/2012.2/CLR4.0/html/Chart_Creating_a_Composite_Chart_Using_the_Chart_Wizard_Part_1_of_2.html http://help.infragistics.com/Help/Doc/WinForms/2012.2/CLR4.0/html/Chart_Creating_a_Composite_Chart_Using_the_Chart_Wizard_Part_2_of_2.html
Sincerely,Sahaja KokkalagaddaAssociate Software Developer, Windows Formshttp://www.infragistics.com/
Please check the below sample to create a Composite chart with a column chart layer and a line chart layer, and let me know if you have any questions.
Sincerely,
Sahaja Kokkalagadda
