The minute I uncomment MarkerStyle Property, nothing shows up? what is wrong with this style?
Hi Noman,
Try setting the Margin to 0 on the Marker. By default the Marker has a bit of a margin and if your Width and Height are small enough you won't see the marker content. Removing the Margin will allow your markers to show with a small size.
Thanks! Margin=0 solved it!
