615
Ignite DataChart tooltip flickers when hosted in XamTile
We have a SL project that uses Xamtiles to display our dashboard.
We recently developed an IgniteUI project that is hosted inside a XamHtmlViewer that is in turn hosted inside a XamTile.
Whenever an IgniteUI Datachart is displayed and then the mouse is moved over the chart a tooltip is displayed.  Whenever the tooltip moves, we notice the screen flickers a lot.
If we remove the XamTile from the project and simply run the Ignite content inside the XamHtmlViewer we do not notice the behavior.
I've attached a solution that demonstrates the problem we're having.
Thanks in advance for any suggestions.
I can't get file to attach to post.  Maybe too big?  Is there another way to get the file to you?
IGFlickeringIssue.zip
