I am trying to set "margin-left" in igGrid cells, inside "iggriddatarendered" event, like below:
grid.on("iggriddatarendered", function(evt,ui){ var gridId = evt.target.id; //getting gridId of current controller var columnIndex;
if(gridId == "_IndexPro") { for(i = 0; i <= 1="" i="" br=""> { columnIndex = $("#" + gridId + "_" + "_DESC_Column").data("columnIndex")-1;
$(grid.igGrid("cellAt", columnIndex, i)).css('margin-left, '20px'); } }
All other css properties are working fine here except "margin-left"
Please let me know what is missing in my code? How to set margin-left in my above code ?
Thanks in advance
Hello Pree Khanna,
Since the igGrid acts in ways similar to a plain html table, the styling of the cells is very similar as well. The css margin properties, just like for the html table if are set for a cell will not be taken into account, because that would have more negative effects and that's why it is standard for all browsers.
I assume you are looking to shift the content of the cells to the right and there could be two ways of doing that:
One way that can be achieved by setting the padding-left instead of the margin-left.
Another way would be to wrap the content of each cell with a div element, and then set the margin-left attribute for those div elements. The wrapping of the content can be achieved by setting the template option for each column. It would look something like the code bellow:
{ headerText: "Product Name", key: "Name", dataType: "string", template: "<div class='myContentClass' >${Name}</div>" }
Let me know if you need more information.
Regards,Svetoslav Krastev,Infragistics
Hi Svetoslav Krastev,Thank you for the reply. padding-left property is working fine as per my requirement.Thanks a lot.
