so I have a Problem with the xamDataGrid and the Sorting of the Groups. I have a DAteValidFrom Column which is Bound to an Nullable DateTime.
When I sort the Column in the Grid the Result is correct:
But if I Group by this Column the Sorting is not correct:
How to fix that with the least effort?
Hello CSchmitt,
Thank you for your post.
It appears from your screenshot that your nullable DateTime field is sorting by the day column, assuming that your formatting of your DateTime is MM.DD.YYYY. You should be able to sort your DateTime field by the actual date by setting the XamDataGrid.FieldSettings.GroupByMode property to "Date." If you are looking to set it on a particular Field, though, you can set it on the Field's Settings as well to have it only apply to that particular field in the grid. The code for that would look like the following:
<ig:Field Name="MyField"><ig:Field.Settings><ig:FieldSettings GroupByMode="Date"/>
I have attached a sample project to demonstrate the above. I hope this helps you.
Sincerely,AndrewAssociate DeveloperInfragistics Inc.www.infragistics.com/support
Thanks that was the Solution which works.
Thank you for your response. I am glad that methods I had suggested work for you on this matter.
