220
Issues with WinGrid since v16.1 upgrade
Since upgrading a project from 15.2 to version 16.1 of wingrid we are getting the following exception.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UltraWinGrid.UltraGrid.SynchImeMode(Boolean restoreOnly)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnAfterExitEditMode()
   at Infragistics.Win.UltraWinGrid.UltraGrid.FireEvent(GridEventIds id, EventArgs e)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.OnEditorAfterExitEditMode(Object sender, EventArgs e)
   at Infragistics.Win.EmbeddableEditorBase.OnAfterExitEditMode()
   at Infragistics.Win.EmbeddableEditorBase.ExitEditMode(Boolean forceExit, Boolean applyChanges)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode(Boolean cancellingEditOperation, Boolean forceExit)
   at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode()
   at Infragistics.Win.UltraWinGrid.UltraGrid.ClearActiveCell(Boolean invalidate, Boolean shutdown)
   at Infragistics.Win.UltraWinGrid.UltraGrid.set_ActiveCell(UltraGridCell value)
   at Infragistics.Win.UltraWinGrid.UltraGridRow.Activate()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode, Boolean byTabKey)
   at Infragistics.Win.UltraWinGrid.UltraGridRow.SetFocusAndActivate()
   at Infragistics.Win.UltraWinGrid.UltraGrid.Infragistics.Win.ISelectionManager.ActivateItem(ISelectableItem item)
   at Infragistics.Win.SelectionStrategyExtended.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo, Boolean forceDrag)
   at Infragistics.Win.SelectionStrategyExtended.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.SelectionStrategyExtended.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1080.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Microsoft.VisualStudio.HostingProcess.Utilities
    Assembly Version: 14.0.0.0
    Win32 Version: 14.0.23107.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/14.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll
    Win32 Version: 4.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Microsoft.VisualStudio.HostingProcess.Utilities.Sync
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/14.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll
System
    Win32 Version: 4.6.1081.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Microsoft.VisualStudio.Debugger.Runtime
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/14.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll
vshost32
    CodeBase: file:///C:/Users/Mike/Documents/Visual%20Studio%202013/Projects/Gozuku%20Stock%20System/Release-02/bin/Debug/GozukuStock.vshost.exe
System.Web.Services
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
GozukuStock
    Assembly Version: 4.3.6.6
    Win32 Version: 4.3.6.6
    CodeBase: file:///C:/Users/Mike/Documents/Visual%20Studio%202013/Projects/Gozuku%20Stock%20System/Release-02/bin/Debug/GozukuStock.EXE
System.Drawing
    Win32 Version: 4.6.1078.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 4.6.1064.2 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Infragistics4.Win.v16.1
    Assembly Version: 16.1.20161.1000
    Win32 Version: 16.1.20161.1000
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.v16.1.dll
Infragistics4.Shared.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Shared.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Shared.v16.1.dll
Infragistics4.Win.Misc.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.Misc.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.Misc.v16.1.dll
UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
WindowsBase
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
UIAutomationTypes
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Infragistics4.Win.UltraWinTabControl.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinTabControl.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinTabControl.v16.1.dll
Infragistics4.Win.UltraWinGrid.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinGrid.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinGrid.v16.1.dll
Infragistics4.Win.UltraWinMaskedEdit.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinMaskedEdit.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinMaskedEdit.v16.1.dll
Infragistics4.Win.UltraWinEditors.v16.1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinEditors.v16.1/v4.0_16.1.20161.1000__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinEditors.v16.1.dll
System.Data.DataSetExtensions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
No code has changed just the version update.
Any help would be appreciated
Parents Reply Children
No Data
