I cannot filter on a date-columns with an Excel Filter. All other types of columns, filtering is working fine
When I unchecked everything and check one or more date, nothing is being filtered in MOZILLA. If I open the filter again, everything is been selected.
In Chrome and IE11, When I unchecked everything and check one or more date, initially working fine, but at the second time when i unchecked 'ALL' and select particular date, all selected date's records and NULL date's records are coming. If I open the filter again, selected dates and NULL date is selected.
This issue is already posted someone at http://www.infragistics.com/community/forums/t/87137.aspx.I used your suggested solutions. But the problem still exists.
Hi SOJAN PAUL,
Thank you for posting in our community!
I was not able to reproduce your issue with version 16.1 . I'm sending you small isolated sample where the proper behavior can be observed.
If your scenario is different, please send us back sample with your scenario implemented so we can proceed with our investigation.
Hi, Petko Petkov,
We are using Version=14.1.20141.2392
Here am attaching the code which am used.
<ig:WebHierarchicalDataGrid ID="WebDataGrid1" DefaultColumnWidth="100" OnColumnMoved="WebDataGrid1_ColumnMoved" OnPageIndexChanged="WebDataGrid1_PageIndexChanged" ClientEvents-Initialize="intializeGrid" ClientEvents-RowCollapsing="intializeGrid" ClientEvents-RowExpanding="intializeGrid" ClientEvents-AJAXResponse="intializeGrid" ClientEvents-Populating="intializeGrid" GroupingSettings-GroupedRowCssClass="row-image-cursor" OnInitializeRow="WebDataGrid1_InitializeRow" HeaderCaptionCssClass="row-image-cursor ig-table-header" ClientEvents-GroupedRowExpanded="setContainerDiv" ClientEvents-GroupedRowCollapsed="setContainerDiv" runat="server" OnDataFiltering="WebDataGrid1_DataFiltering" Width="100%" OnGroupedColumnsChanging="WebDataGrid1_GroupedColumnsChanging" OnColumnSorted="WebDataGrid1_ColumnSorted" EnableAjax="false" DataKeyFields="Client Name"> <Behaviors> <ig:ColumnMoving Enabled="true"></ig:ColumnMoving> <ig:Activation Enabled="true"> </ig:Activation> <ig:Filtering Enabled="true" AnimationEnabled="true" FilteringClientEvents-DataFiltered="filterResponse" FilterRowSelectorImageCssClass="ggg" FilterRuleDropDownCssClass="ig-data-filter" AnimationType="Linear" FilterType="ExcelStyleFilter" /> <ig:Sorting SortingMode="Multi" Enabled="true" /> <ig:Paging PagerAppearance="Both" Enabled="false" PagerMode="NumericFirstLast" QuickPages="10" FirstPageText="First" LastPageText="Last"> </ig:Paging> </Behaviors> <GroupingSettings EnableColumnGrouping="True" GroupAreaVisibility="Visible" InitialRowExpandState="Collapsed"></GroupingSettings> </ig:WebHierarchicalDataGrid> <ig:WebHierarchicalDataSource ID="ReportWritterWebHierarchicalDataSource" runat="server"> <DataViews> <ig:DataView ID="SqlDataSource1_Schedule" DataSourceID="ReportWritterObjectDataSource" /> </DataViews> </ig:WebHierarchicalDataSource> <asp:ObjectDataSource ID="ReportWritterObjectDataSource" SelectMethod="GetReportWritterData" TypeName="Homecare.Web.Views.ReportWriter" runat="server"></asp:ObjectDataSource>
Pls advise me
I see that you are using WHDG instead of WebDataGrid. I would like to let you know that we have separate thread for WebHierarchicalDataGrid. Also I asked for sample - attached project or web site as I sent. Your code snippet shows some dependencies that are not provided as server side handlers of the grid, its data source, etc. Please provide us isolated sample as attachment that demonstrate the issue.
Hi Petko Petkov,
Here I am attaching the detailed code for WHDG which i used.please check this code and advise me how to resolve this issue
