Is it possible move NavigationToolbar instead of FileMenu on Ribbon? See screanshot.
Hi Paul,
Short answer, easily, no. We primarily went for emulating how Microsoft designed the toolbars, and that level of customization wasn't built into the control. You can request that functionality via a feature request here : ideas.infragistics.comThat being said, there are a few ways you can probably work around that, the easier of the two approaches might be to first add the NavBar to your form, then add the Ribbon wrapped in a user control to it. Make sure to keep MDI merging off. You would need to manually handle the anything you want the two to know about each other. The other route might be to use a creation filter, and just swap the UIElements as they before they are drawn, you may have issues with sizing, and need to reposition the rest of the tabs as well. But it is doable. http://help.infragistics.com/Help/Doc/WinForms/2012.2/CLR4.0/html/Win_Creation_Filter.html
Let me know if that works for you,Michael GermannSoftware Development Team LeadInfragistics
Hi Michael,
First way I think it does not suit me, Ribbon as userControl should be correctly collapced and resizeble in the toolbar. (or i didn't understand. can you send examle?)
Second way - can you send example How do it do with swap the UIElements?
Unfortunately what would be required to get the CreationFilter sample to work, again while theoretically possible, would require extensive customization that we don't have the resources to supply that kind of custom sample. The primary issue with it is, while you can shift UIElements around, if they are not the same size, then you have to shift the UI Elements that it would overwrite, and then those UIElements might then displace others, etc. That being said the first scenario, I have the sample attached.
Let me know if this helps,
