I have need to automate the application using UFT 12.53 and having infragistic of v13.1. Which version of Test Automation I need to download and from which site I can Download it.
Thanks.
Hi Ketki,
Your Infragistics version and Test Automation version should be the same. So if you are using Infragistics V13.1 then you need Test Automation V13.1. You can contact our sales at Sales@Infragistics.com to purchase a Test Automation key for V13.1. Once you register your Test Automation key you can find its download link in your “My Keys and Downloads” page when you login to your account at Infragistics.com.
Please let me know if I may be of further assistance.
Sincerely,Sahaja KokkalagaddaAssociate Software Developer
Hi Sahaja,
Thanks for your reply. I will consider your solution but before that can I install trial version of Test Automation and see if object are getting identified. If so then I will register for key.
Also, I want to know whether I need additional patches for UFT 12.53 with Test Automation to identify object. And how the Test automation works. Currently, my scripts shows as its clicking on co-ordinates
SwfWindow("Application").SwfWindow("Applicationform").SwfObject("0.0000ob12").Type "1.0"SwfWindow("Appkication").SwfWindow("Applicationform").SwfObject("0emo_job_2").Click 44,10
Please advise.
Ketki
I application is using infragistic win forms of v13.1. So can you please tell me if can I download "Download TestAdvantage for Windows Forms (for HP QuickTest Professional software) 2013 Volume 1". I have UFT 12.53.
Yes, you can download TestAdvantage for Windows Forms 2013 Vol1 if your application is using Infragistics WinForms 2013 Vol1. UFT 12.53 is the latest so you don’t need any additional patches for this. To read more about the supported IDE’s for Test Automation, refer to the below link.
http://www.infragistics.com/support/supported-environments
You can use the below link to download TestAdvantage for Windows Forms (for HP QuickTest Professional software) 2013 Volume 1.
Thanks for you reply but I am still not able to complete the set-up.
As my AUT is using Infragistic version 13.1, I have downloaded the TestAdvantage version 2013 volume 1 as you mention in your post.
But for downloading "TestAdvantage version 2013 volume 1", I need to down grade my .net framework version to 4.0 and because of that my UFT 12.53 is not opening as it need .net framework 4.5.
Please let me know what is the best tool and version that I need to install.
Thanks in advance.
Could you please suggest me on my question as how can I resolve this versioning issue. Is there any way or does test automation does not support backed version infragistic.
You don't have to downgrade your application to .net framework 4.0 in order to download or use Test Advantage version 2013 Vol1. If you have Infragistics 13.1 and UFT 12.53 and .net framework 4.5 then you should be able to download and use Test Automation 13.1 without any problem. Are you getting any issues while downloading it?
To check out the supported IDE’s for Test Automation please refer to the below link.
