We are dynamically updating the xamgrid itemsource with data then reducing visible record counts with multiple header filters. How can you retrieve the count of filtered records (numbers used to generate the xamgrid paging)?
Hello Nick,
Similar question was discussed in the following forum thread:
http://www.infragistics.com/community/forums/t/51363.aspx
You can use Filtering or Filtered xamGrid events handlers to get the xamGrid Rows Count.
I have attached a sample application demonstrating a similar scenario.
Sincerely,
